an alternative way to do IRS with Ford rear
#136
#138
I have started mocking up the installation of my Tbird IRS into my 56 frame. I will be welding the IRS cage into the frame instead of using the soft mounts. At this point I do not know if I will be using springs or air bags. I will probably start with springs and convert to air bags when my ship comes in. That being the case, I would like to fabricate the spring perches with the mounting holes for the air bags. Does anyone have templates for these holes or know where I can get them? Also, what size bags is everyone running? Also, what has everyone been setting their pinion angle at?
Thanks
Scott
Thanks
Scott
#139
OK, I have looked at all of the pics and have a question. My truck is on the road with a 8.8 rear-end and a 23 gallon BroncoII gas tank under the rear. I have concerns about tank placement with the IRS since there is only 3'' of clearance from my diff. cover to the tank. Has anyone used the IRS with a rear mounted tank and if so, what tank did you use?
#140
#141
_________________________________________
46 Ford Tudor - Street Rod
48 Ford F1 - Darkside Custom
"Never get into a box you have to think outside of"
monsterbaby
13
10-04-2022 11:35 AM
MIKES 68 F100
09-17-2021 11:54 PM
Rokcrln
59
02-25-2017 05:50 PM
cogester
09-25-2015 10:32 PM
HkyswiM
12-26-2011 05:41 PM
