Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2004 Lightning tonneu cover
Old 03-13-2007, 03:47 PM
Sixth Pony's Avatar
Sixth Pony
Sixth Pony is offline
Help!
I have a 2004 Lightning with the tonneau cover. I have lost the driver side
rear most 'end cover? with the handle that allows the rearbar (closest to
the tailgate) to be removed. The tonneau frame has 2 bars that hold the
middle of the cover up to keep water from puddling on the top of the
cover.
The Ford guys here have ordered 2 different parts, neither of which was the
correct part. I called SVT they indicated that Ford outsourced the covers
and perhaps there is a tag on the cover, sure was FORD.
There is one of these on each side of the rear portion of the tonneau cover
frame, both have a 'pull down' on the bottom that is spring loaded that pulls
a metal 'pin' down which allows the rear frame to be removed.
Unfortunately the part numbers on the passenger side don't correlate as
Ford part numbers: on the body of the part 331.100 R, on the top of the
handle 333.50 A R.
Any assistance would be most greatfully appreciated!
Thanks
Art
Old 03-22-2007, 09:46 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Bump.
Old 03-22-2007, 09:52 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
There is a fellow Lightning owner at SVT Performance who works in the parts department at a Lincoln dealership. Because he is a parts guy who owns a Lightning, he might be able to come up with the proper part number so your local dealership can order the correct part. His registered name over there in the Gen 2 forum is "RIDE THE".
His real name is Eric.
I'm pretty sure he wouldn't mind taking a crack at identifying the part for you.
Stewart
