loose steering
loose steering
Of all the many places Bronco's get loose steering, the steering box is about the last place it'll get it; plus, you can easily muck up a prefectly good box, real quick. As with any rig, head for the front-end/alignment shop. Mine's older (an 83'), and has the twin I-beam front end - not sure if your's does. The first thing to go out is usually the tie-rod ends. After those, inspect the "radius arm bushings" (at the back of the "A-frames" trailing the axle assembly)
OF COURSE - also check the front wheel bearings. All this is standard in a good line-up shop. Beyond these things, the guesses can get trickier. My 83 has 245,000 miles, and drives good - for a short wheel-based Bronco. The final key was replacing the U-joint in the steering colum...
HOW FAST DO YOU WANT TO DRIVE OFF-ROAD ANYWAY?
loose steering
Install Energy Suspension's urethane bushings. My radius arm factory rubber busings were crushed so I swithed to urethane thinking they would last longer (I changed all the suspension bushings from rubber to urethane).
I didn't expect much change in drivability. WOW, was I wrong. It drives like a completely different truck... way tighter steering. This was probably the best mod I did for my Bronco!
1996 Ford Bronco, 5.8L:
-Done:Hypertech III,Powerstat, K&N FIPK,cooler TBody bypass,Mac equal length headers, Gibson cat-back, Urethane bushings, BF Goodrich TA's, Roadmaster active suspension, Nozzle lights, Euro taillights,MSD Blaster Coil, MSD Cap & Rotor, Taylor spiral pro wires, ASP undredrive pullys
-ToDo: Edelbrock performer intake manifold & 56 Tbody, Granetelli MAF, maybe Kenne Ball supercharger instead!
loose steering
I disagree and agree you should check all your front end componets but it could be your steering box I know several ford owners that have had to adjust there steering box to get the slop out. This makes the steering tighter so it handles better. Just remember to only do a 1/2 or 1/4 turn at atime dont over ajust. We just did my buddies bronco a couple of weeks ago. Also this is more common when you start running larger tires
I have had the same issue. 1996 351 - all new bushings, new tie rod ends, new u-joints and now third steering gear box.
35 AT BFG's. Not sure what else to change out or adjust.
At 75mph on highway, its all over the place. Offroad, very loose and tought to keep stright in desert enviroment. thoughts?
the steering gear can only be adjusted so far before it is not useable. the reman gear i bought last fall has slop in it so i do believe that all the front end parts have very minor wear and it all adds up.
i suggest getting a rancho steering stabilizer for the larger wheeled folks of this forum.
Guys, I don't mean to be rude.. but I have been down this route.
Adjusting your box can make a difference, but I wouldn't recommend it.. it'll only last a few months before it starts acting up even worse. If you're anything like me, you'll make it better but still not be satisfied, then try for more and end up breaking it completely.
Steering stabilizers absolutely will NOT help your steering tightness. It's there for bumpsteer and bumpsteer only exists if you take shortcuts when lifting.
My old bushings were in better shape than I thought, but when I replaced all of them I noticed no difference in steering tightness. I did notice a difference in braking with radius arm bushings, and got less alignment change when I went in reverse when I did my pivot arm bushings, but that was it.
The Redhead box and rod-ends made the biggest difference, however, the Redhead didn't make my steering feel super tight like I was expecting. The ONLY thing not brand new/fixed right now is my camber, which is definitely off. My wheel is super loose, my Saginaw box made it feel even worse, but while driving I noticed my wheel IS turning ever so slightly when it feels like it isn't..
it's just a mixture of non-road tires with a bad camber.
Yeah, I get it now.. I thought I was replying to the first guy, then realized you were bumping an old thread to ask yourself.. sorry about that, my fault for being dumb. I thought the guy had done a SAS then asked why his steering was loose, then a bunch of people read the thread and replied not knowing it was a 9 year old thread and all kinds of confusing stuff
How does your frame look at your steering box? You sure it isn't cracked? and some of the advice still stands, get under there and see where it is loose. It's also quite possible your alignment guys are terrible at their job. I had 4 bad alignments before I went to a shop who gave me actual degree printouts on the alignment, first time it drove straight and well.
If you have a 6'' lift, I just did a tierod flip (on top of the knuckle instead of below it), made a lot of difference.
