Shredded Belt
Shredded Belt
So, jump started the truck today, got it running, left the hood up, came back and noticed black dots all over the front quarter panels in line with the belt. took it for a ride to warm it up, as i live in New England and not a mile down the road the belt gives out, shredded to ****. The week before i put a new idler pulley on and no problem til this. I noticed grease around the vacuum pulley, well im pretty sure thats the pulley, its the one right above the powersteering pulley and below where the A/C would be. Im basically stuck here wondering if i should put another belt on there and hope it doesnt shred, or start replacing parts. Any insight would be greatly appreciated
How old was the belt?
Are all the pulleys rotating easily? Are they all in line with each other? Front to rear. The PS pulley can be intalled to deep or too shallow causing misalignment. Sometimes the pulleys can become too smooth allowing the belt to slip just enough to wear the belt prematurely. Steelwool or Scoth brite the smooth pulleys. (Non-ribbed)
The alternator, vacuum pump or AC pump could be siezing up.
from what i could see they are in line with each other, all pulleys are moving freely like they should with the exception of the vac pulley, im not sure how free that one should be, it turns a little then gets tension and then turns more, I assume thats how that one works, but not too sure. Im not sure how old the belt is, i bought the truck about 4 months ago and havnt changed it until now. after i replaced the idler pulley i put the same belt back on, i didnt check it to see if it ripped, the belt remained on all pulleys but the idler because the bushing wore out and just lost tension.
adr3naline
18
10-07-2013 08:03 PM
rolltide3006
16
04-23-2011 10:50 AM
trotsky13
28
11-29-2009 07:04 PM
quicklook2
12-11-2006 04:05 PM
txicestorm
26
10-19-2005 05:13 PM
