2001 F 150
Old 01-26-2007, 07:24 PM
panelguy's Avatar
panelguy
panelguy is offline
2001 F 150
Hello i just bought a 2001 f150 Xtr, with the factory tow package.I'm wondering what the tow ratings are for this truck and what is included in these factory tow packages. It has a 4.6 liter v8 auto trans.
Old 01-26-2007, 07:41 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
Your owners manual should tell you. Are you planning on pulling much? The 4.6 will do it but not as easily as the 5.4.
Old 01-26-2007, 08:03 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
You have not given enough information.
Is it a super cab, screw, reg cab, 4x2, 4x4 etc.?
Tire sizes also enters into the mix at some points. 16 or 17"
What rear gear?
The max gross towing weights ranges from 10,000 to 11,500 lbs over all the combinations.
Over the same range, the seperate towing weights range from 5800 to 6900 lbs.
The 5.4L motor makes a big difference on these max weights per model.
All this assumes an automatic transmission.
saleen5.8
15
11-07-2013 03:21 PM
panelguy
1997 - 2003 F150
08-26-2013 04:10 PM
calidogj14
2009 - 2014 F150
03-13-2010 06:42 AM
thunderbolt427
1997 - 2003 F150
06-21-2007 08:37 PM
momdawg
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-25-2006 11:34 AM
Quick Reply: 2001 F 150
