2000 V10, won't start I'm stumped please help!!!
Okay, so my V10 won't start with just the key anymore... This started while I was on vacation in CO over christmas during the blizzard... She's got power... Even put in a new battery... New Solenoid on the firewall, still, when I turn the key, NADA, nothing, zippo a big lot of nothing...
I can jump the solenoid posts and she fires just fine... No problems there... But its a real pain to pop the hood and jump the posts just so I can start my truck...
So, new batter, new solenoid on the firewall, what next... Any ideas...
BTW, I tried a few searches, and I kept getting over 500 responses!!!
Guys remeber the guy who had this problem yrs ago?
Chk for corrosion in the wires heading down to the starter .
we pulled are hair out on this one.
The wires were green with corrosin and being eatin away inside but the wire insulation looked great from the outside.
He replaced that wire from the relay down and his problem went away
Could it be????
Rich
Could it be????
Rich
Could it be????
Rich
Could it be????
Rich
To the ORIGINAL POSTER: When you say "jump the solenoid" - are you jumping across the two big posts, or the small post ("S" on the solenoid) to the battery side?
Originally Posted by HeathJohnson
Both big posts with a screwdriver...
If you take that screwdriver, and cross that small post to the big post that goes back to the battery, will it start? If not, the solenoid needs to be changed
Originally Posted by krewat
If you look at the solenoid, you will see a small wire going to it, that should be energized when you turn the key to "start".
I'm on my third solenoid... From different stores... So I'm HOPING that this one would be good... Maybe I'll get really lucky and my stock one is still good and I can just take this one back...
