4:30 v. 4:88 '08 F450 tow capacity...
https://www.fleet.ford.com/showroom/...ng/default.asp
Here is the 08 towing guide from the Ford Fleet page....
Done deal, now we need to find a driver
Originally Posted by 1968gtcs
Why sure, but keep in mind we will be ruffing it. 37" wide screen TV, 22cubic in refer for the beer, leather reclining chairs, fireplace, and if I can figure out how to put the hot tub in the basement on the slide out shelf. Yep we will be rufffing it..
Originally Posted by DFord79
It is the same one that
http://www.sunrisefordfleet.com/pdfs/misc/2008%20Tow%20Guide.pdf
Has posted.
Ford has all the updated info on fordvehicles.com. Navigate to the 08 information video. Then click on configuration. On the configuration page there is a tab on the upper right hand corner that refers to a PDF format download. This has the detailed infor that everyone is looking for. It was just updated a few days ago.
Originally Posted by Customz
Is there any reason why one couldn't buy the 4.30 geared truck and gear it to 4.88? I realize cost is the obvious issue, but still don't see the rationale of detuning the motor as a result of lower gears.
This truck is intended for open interstate(mostly) and 4.88 gears will drink that gas if the rpm curve was not changed accordingly as they have done.
Its a semi with a bed ..
#29
Pulling a 24,500 pound trailer the 4.88 geared truck would get the better fuel economy than the more powerful non-detuned engine 430 geared truck and the 4.88 geared truck would pull the load up a hill faster.
When pulling only a 12,500 pound trailer the 4.30 geared truck and the 4.88 geared truck would both get the same fuel economy and both would crest the hill at the same time but the 430 geared truck would be taking the lead.
Pulling a trailer weighing less than around 12,500 then the 4.30 non-detuned engined geared truck would get the better fuel economy and get up the hill first before the de-tuned engined 4.88 geared truck would.
When choosing between the detuned engine(4.88) or the non-detuned engine(4.30) you need to decide what weight trailer you will be hauling.
Picking the right one will save you gas money and some travel time over the road also the engine would be more appropriately in its peak best running tuned power band for that load and the engine will thank you with longevity..
#30
How do you know they changed the HP/TQ curves?
I'm willing to bet that both motors make peak torque at 2000 rpm.
