Can't get the ODB-2 to read the truck??
Old 10-10-2006, 09:08 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
Hey guys I have no idea what's wrong with the truck?! It runs fine and every thing but my CEL is on and the reader won't pull codes or act like it's even plugged in! I've tried Advance and Oriely's but neither of them could read it so I went to ford and they said to check the power plug fuse cause they run the power off of it.. I checked it out and the fuse is good so I'm stumped.
Any help?
Doc
Old 10-10-2006, 09:13 PM
ReAX's Avatar
ReAX
ReAX is offline
Do you have a 1996-current vehicle? What kind of reader do you have? Have you looked that the aldl port, and possible hit it with contact cleaner?
Was ford able to access the body module/GEM?
Old 10-10-2006, 09:19 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
Sorry I have a 02 F150 and couldn't get into ford till next week and they just gave me the fuse idea to check first. ALDL port??
Old 10-10-2006, 09:48 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
You have a blown fuse. Check the fuses in tha cab and also the ones under the hood in the distribution box, It is a always hot fuse, not keyed.
Old 10-10-2006, 10:19 PM
ReAX's Avatar
ReAX
ReAX is offline
Assembly Line Diagnostic Link, the port under the dash. My 02 F250 doesn't have an under hood fuse box, so if you don't find one they are all under the dash.
The aldl port is kind of low mounted and could have trash stuck in it. The fuse is going to be the first thing to check, but there maybe something in the port shorting the power wire out.
Old 10-10-2006, 10:31 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
The F150's have a box under the hood on the drivers side. It is full of fuses and relays.
There is also one under the dash.
Old 10-11-2006, 07:53 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
well I will check them both out and see what comes up thanks guys!
Old 10-12-2006, 07:07 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Your truck has a DLC (Data Link Connector) to plug the scan tool into. It is federally mandated. I've never heard of it called the ALDL before....
Pin 16 of the DLC provides operating power to the scan tool via fuse F3 in the under-dash fusebox. See page 180 of your owner's manual.
Steve
Old 10-12-2006, 07:17 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
Yeah I knew that and checked the F3 fuse and it was good. So I don't know why it would still not read!
Old 10-12-2006, 11:02 PM
projectSHO89
Have you checked at pin 16 with a meter? Sometimes the fuse isn't the problem...
Steve
Old 10-13-2006, 04:39 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
no but i will!
Old 01-23-2007, 05:32 AM
talnro's Avatar
talnro
talnro is offline
2001 Exp. doing the same thing. What did you find?
Old 01-25-2007, 07:44 AM
talnro's Avatar
talnro
talnro is offline
Mine was the 3rd fuse . Thanks guys.
Old 01-25-2007, 04:10 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
Found out Advance Auto is a waste of time! just happened to be at oreileys and they ran it and pulled about 7 different codes for me!
