Fuel Leak 2000 Ford F-250, 7.3 Diesel
When I start my truck, I have a diesel leak from the fuel water separator tube.
I have opened and closed the fuel filter drain valve, but it did not remedy my problem. Will I need to replace the whole fuel filter assembly or can the drain valve be cleaned or are there oring that may need replacing?
O-rings will fix it. Click on the link (my write-up) at the end of this post for repair details, not hard at all. Hope it helps..
Tom in MO
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM (or delete) and shocks....!
Drain valve repair write-up.
Tom in MO
