DRL's only, not brights or fogs? Help!
Hello there, new member here. Had a Ranger last year and just bought a '97 F150 today (4x4, XLT, 4.6L).
I posted this in the electrical section as well, but thought I might get a fatser answer if I posted here as it is viewed more.
On my way home I turned on the headlights and all seemed fine. But when I tried to turn the brights on, no change. If I pulled back on the turn signal stalk the brights come on, but if I push on the turn signal stalk they don't come on. I also realized when I got home that my fog lights don't work either. My truck has DRL's (made in Canada), and I thought they were supposed to be dimmer than the regular headlights, but when I turn my headlights off/on the brightness of the headlights doesn't change. This makes me think that maybe none of my headlights are working?
I checked all my fuses that would relate and they are all good. I don't see a relay indicated in the manual that would cause this if it was bad either.
Any suggestions? Is a switch bad? Thanks in advance for the help, John
I’d have a look at the column switch, the fog lights are wired to shut of when the brights come on. An issue in the switch might be preventing both your bights and fogs from coming on. As far as DRL’s, I’ve never heard that they are supposed to be dimmer, but then again I’ve never seen a ford with them, so who knows. I'll try to dig up some diagrams later.
DRL will turn off when the e-break is applied and the head lights will stay on if turned on.DRL are 30% of the high beams .when the DRL modual fails the head light low beams should still work as it uses the high beam only.The low beams are not in the DRL circuit by design so it fails safe and leaves you with all your normal lighting.
cheers
cheers
