head bolts
Clyde,
You might be able to find something tht will work here;
http://www.mcmaster.com/
Thats where I found my exhaust manifold bolts, about 3 times cheaper than Summit, PAW, Speedway, JEGS, etc
Bobby
Bobby
If you mean they are thinner in the middle of the length of the bolt, I think that is the factory shape of them. If the threaded part looks stretched and a nut won't run up them easily, then they are are shot. If they are very rusty, toss 'em. Try measuring the overall length (from underneath the head to end), see if they vary much.
You can't go wrong replacing them, but it would be pretty hard to stretch these without stripping the holes in the block. The deck is not that strong, unfortunately.
