TBI problem on 1989 350/351 Windsor
My 1989 dually has a high idle problem. I took apart the TBI unit along with the poweraid block. Clean them both with fuel injector cleaner and put back together. If I tap the accelerator it idles high until I "tap" The spring lever on the TBI unit itself and then the idle goes down to normal. I have tried using wd40 but it seems that the butterflies are not seating properly. I thought butterflies just open and close and thats it?
Could these things be wore-out? Has anybody have this problem before? What it the solution?
Thank you for your help!!!
40yearvet
01-31-2009 10:21 AM
fireranger40
01-03-2007 12:02 PM
Whiskers
02-11-2001 07:03 PM
