How big a problem, plug blowing?
Originally Posted by pronstar
all I've got to say is I'm lucky!
i see the ways to prevent and clean what falls into the cylinder, but it sounds like taking a chance to me....worrisome.
Many, many people, on this site and others, and a few people who I know personally, have used Time Certs to good effect.
If it means anything, the 'net is usually a gathering place for people posting their problems, and I have not read one bad report relating to the Time Certs.
Some engine builders have even put them in as a preventive measure as they assemble their engines.
I think it's much less invasive than taking a cylinder head off. If you were using a high-speed drill to put the insert in, then I could see your concern, but if you do things carefully/slowly, I don't think you'll have a problem
Hello Everyone. Well I went 4X4 again and I was pulling my 2 quads with a loaded trailer of camping gear for 2 days and 6000 miles so far from putting in the new plugs I haven't had one blow or a tinking noise. I didn't retorque them but I guess I could check and see if they need them. I do need to pull my door panels of and get the sand out. I crossed a long wash and getting in and out of the truck put a lot of sand inside. The way I see it, is if it ain't knocking keep on truckin. I would like to get me a 2004 or newer F350 next to pull a toy hauler
I have had two plugs blow out one at 80,00 and the other at 120,000 on my 2002 f150harley davidson. I took the truck to ford and they offered to put a new motor in for $6,000 plus. They also said that they was aware of the promblem with the spark plugs ejecting. They said they would lower the cost on the engine $800.00. Has any body contacted the local news for help with this promblem about ford. Any body intersted in contacting fox 4 news in Dallas, Texas this week and explain to them the promblems you have had with this, they would love to hear your story
#28
Originally Posted by Mr. G
I have been debating if I should change mine on my 2000 4.6 with 45K. It is hard to decide if leaving them in for 7 years is worse than disturbing those 4 threads by changing them.
Remember, only a small percentage of trucks has the problem.
The majority of them don't ever eject a plug.
If I had the engine out, or the heads off, for some other reason, then I'd do it.
#29
What exactly is happing when a plug get's blown out? Does the plug loosen up, then tear the few threads out as it is ejected? What is causing the ticking sound prior to the plug ejcetion?
Actually I think the plugs are easier to get to in a van than a truck. You can get to the front plugs thru the front and the rear ones by removing the motor cover.
#30
