truck won't start
truck won't start
Guys I'm new to the forum and I own an older F150. My truck is a 1994 F150 with a 4.9 liter auto. Last Friday I went for a spin and when I started the vehicle it started slow and the next time it won't start. The starter was bad and I replaced it , still wouldn't start only clicked when I turned on the ignition, I had a spare solenoid and I replaced it ,same problem. Cleaned all the connections still same problem. I reviewed some of the treads here whch lead me to a neutral switch, changed that, same problem. I'm puzzled any suggestions?
Jim
__________________
Jim
__________________
truck won't start
Thanks for the reply, I tried that even replaced the connector, still only a click. What about the air bag or ignition switch? I did have the air bag light blicking for a while before this happened.
Jim
Jim
truck won't start
Originally Posted by mantta
Mine was doing something similar. I got rid of the 6' ground cable that goes all the way to the starter and put a short #2 ground cable to the alternator bracket. Problem solved.
Thanks
Jim
You know, that original ground cable that is around six feet long is about the size of a cheap K Mart jumper cable. Lots of resistance. Before I changed mine, the radio would loose it's memory every time I started it and the alternator did not seem to be charging the battery like it should. That all went away when I put the short #2 cable to the alternator bracket. Don't forget that little ground wire on the negative post, you will not get any fuel with it disconnected.
