5.4L 3V spark plug change question
#151
Originally Posted by wasa 4246
I am new to this sight and I don't think I can post a picture. Can you help me out here? I do have a picture and yes we are producing this tool.
Is this a tool you will make available to the consumers or is it just for dealers?
Any info on cost or how we can find out about it?
Email at patriotcustoms@comcast.net
#152
What I meant was alot of people are waiting until they have over 50k to 75k before they have a tuneup and the warranty is gone. By this time it's a sure thing the plugs will break. I've heard that the dealerships are sticking the cost to the customer for removing the head. You have to remember these plugs were first used in 2003 and techs weren't aware of the problem until the vehicle already had to many miles. If you change the plugs before 50k miles your probably safe.they have broke at 40k.
#155
Originally Posted by exiled
Yea in that sense, warranty cant cover if there is no warranty. If you change your plugs when your truck is out of warranty and 1 breaks you have to fix it or pay to fix it. If you take it to a dealer and unless they tell you before hand that in case of a breakage you have to pay to remove the head they can not charge you. I'm not going to say that dealers have'nt tried to charge cause I'm sure some has. Simple fact is, it was'nt broke when it whent in the shop. It cant come out broke.
#156
As far as I know there was a change in the plugs in 2008. A friend that is a Ford Tech did have plugs break at 40k on a 2004. But it usually is after 50k. The problem is, alot of people thought they didn't need a plug change until 100k starting with the 2003 year and waited until there was many miles and that is a big problem now.
#157
I once caught the mechanic at a big Ford dealer faking changing #8 spark plug on my '97 F150 (311,000 miles now). I'm sure he wasn't the only one to come up with that time and labor saving idea. Changing spark plugs used to be a routine job, no particular problem, now they made it so you can barely get at them.
#159
Originally Posted by F0rdzTuff
Ok, I have a question. I bought an 08 Screw, and my maintenance guide says the plugs don't need changed until 90k miles. Everyone keeps saying 30k. What's correct? I used to work for Ford a couple of years ago, and we'd do the plugs at 60k for most of the vehicles that would come in for service. Did they make changes between 06 and 08 negating the need to change the plugs so early? I know they recommend oil changes at 7500k now instead of 5k, and it runs on 5W-20...Comments? Suggestions?
The 100,000 mile plug change is older than 03. My 97 F150 5.4L had a 100,000 mile plug change. It done it fine. I have'nt heard any info stateing that the 3v plugs wont last 100,000. Its just getting them out with the carbon buildup and the unsimalur metal thing that makes it bugger to deal with.
Take this for what its worth. You decide whats best for you. Its takes me maybe 30 minutes to pull the plugs and clean 'em up. Gives me peace of mind. The truck has I think 69K on the clock now. It still runs like the day we got her.
#164
Originally Posted by BamaDave
I have an 04 with 72000, I don't think my plugs have ever been changed. What should I do(no warranty).
#165
Broken electrode nightmare
Went to change the spark plugs at 50K, #7 broke inside the head, did not have a tool to try to get it out, took it to the dealership, they have soaked it for 30 hrs but is not coming loose; so now the next step is to pull the head off and send it to a machine shop to clean the thread, now the bill suddenly grew to $2,600.
There is always a first time, looks like now it was mine.
Now they are adding a "anti-seize" compound at the factory and changed the design, I hope it works.
