ZF TRans help
Wow....you've got bigger stones than I do ripping a ZF apart.
The main and counter shafts....shift rails, forks, ....everything are assembled on a bench and end loaded as an assembly into the case.
I'm not even sure if it's possible to load the case a piece at a time, but I sure hope you figure out a way.
