Whoops
Whoops
Ok, I made a test blender batch about a week ago, got it to work. Now yesterday I ran a 20 gal batch, off(starting out small so as not to waste too much veggie oil, when I get into full swing I will turn out 100 gal at a time!) I let it sit over night to seperate, and this morning, no seperation, its brown and apparently didnt react. So I currently have another batch mixing with some more lye added, so tomorrow morning will tell all.
Andy, Sounds like either to little Lye for the FFAs that where in the oil, or there was some water in the oil. How many grams of lye per liter did you use? If you did not make a mistake with your measurements, you probably had excess water. Either way you should be able to re-heat the oil and add extra lye and save the batch.
FABMANDELUX.
FABMANDELUX.
FABMANDELUX.
Well I didn't realize you could save a batch, that one has been poored down the hill. However, today, while I was working my dad made another batch, it also didn't react, however he added some lye and saved it, and, IT WORKED!!!!!
I HAVE BIODIESEL.
TOMORROW ON MY WAY HOME I'M GOING TO PUT 20 GAL IN MY GRANDPAS EXCURSION. IT HAS 290,000 MIL, SO IF IT GETS MESSED UP, WHICH I KNOW IT WON'T, BUT JUST TO BE ON THE SAFE SIDE, IT WON'T BE AS BIG A DEAL.
I HAVE BIODIESEL.
Originally Posted by Trent Fliginger
let us know how it turns out. What are you using for a setup? I think after Christmas, I am also get going on making something. What is an "open" processor as opposed to an Appleseed?
An "open" processor is just that, you can see the reaction happen. If you have a problem [generally some excess water] you can add additional lye and force the reaction to completion, thus saving the reaction and your time.
Open style processors use mechanical mixing, and only require about 30 min of mix time.
All appleseed processors use pumps to do the mixing. Pump mixing is inefficient at best, and generally requires more time to mix. The seminar I went to on Monday had a commercial "appleseed" style processor there, and his process requires a 2 step mixing process. It uses the 80-20 process [which has NOT shone any increase in performance] and requires 2 mixing cycles. the first cycle is a 2 hour mix time with 80 percent of the methoxide, then another 2 hour mix with the last 20 percent of methoxide. What a HUGE waste of time and energy! My open style processor produces a 50 gallon batch every 30 min!
FABMANDELUX.
I can see the reaction through the top, but I built mine with old big truck fuel tanks, so it is a closed system. I also am using pumps for mixing for now, but will probably one day have a better mixing system. Is there a chemical you can use instead of water for washing, I plan on making it to where I can evaporate the methanol, but for now do not want to do a water wash.
You will need to switch over to mechanical mixing however, as pump mixing Magnesol is a no-no [just ask "Jeep 1947"]
FABMANDELUX.
Mixing Magnesol
Magnesol http://www.fryerpower.com/store/page1.html is the chemical to use for dri-washing.
FABMANDELUX.
FABMANDELUX.
Whats the issue with Magnesol and pumps?
