Front right tire leans outward
When or if you go get an allignment, I'm sure the shop would check for worn or bad parts. Some shops won't do an allignment unless the suspension is all good and tires in good shape as well. Start poking around under the truck for anything loose or out of place in the front suspension components. Have someone turn the wheel all the way left and then right while you observe.
Bought it a few months ago. Standard usage, nothing out of the ordinary (trips to get straw, poultry to slaughter house, etc).
Have been tinkering with it. Only front end work I've done is new tie rod ends. They were quite worn out. Steering is still quite loose, I'll be checking/adjusting the steering box soon.
In the process of oil pan, rear seal, headers, Cat, cat-back exhaust.
I'll attack this front-end issue when this big project is over. I'm just planning ahead at this point for the front end. It probably wouldn't hurt to do the ball joints though, not sure when the last time they were done/checked.
To check ball joints jack up the front end and grab the tire on the top and bottom and wiggle ( not side to side but top to bottom). If the tire wiggles then it is the ball joints. Does the truck drive ok? Don't know why anyone would pay 20 bucks for inspection just go get a front alignment most places I've gone will not do a alignment if there is a bad part and they will tell you for free what part is bad. But it is not hard to see what front end part is bad just do alittle checking. It helps to have a second person for checking the tie rods and etc since wiggling the tire and looking is difficult.
Yeah Conanski, I'm leaning towards a good ol' fashioned ball joint inspection at this point. I've been trying to find info on those shims. Does a new set of ball joints come with the shims (this will be my first truck ball joint experiance)?
I guess I should plan on doing both sides since only God knows the last time they were done/looked at.
Maybe I should concentrate on my oil pan job from hell first.
