63 unibody input on tranny
Stock 351W? If so a t-5 from any mid 80's to early 90's mustang will bolt up with little to no problems on the 351W. The problems start when you try to install the T-5 or the hydrualic clutch master cylinder. The crossmember under the firewall will force you to mount it really high or cut it out altogether. You can find the diamentions and how to convert to manual linkage at this link. Granted it is for a mustang but you will get the idea.
http://www.fordmuscle.com/archives/2000/09/t5swap/
larryejoh
16
07-24-2012 09:45 PM
