IMRC Stuck open
IMRC Stuck open
Just had my 4.2L '97 F-150 fixed - replaced intake maniford gaskets, water pump, MAF sensor.
It ran like crap, about 3 miles to the gallon with coolant in the oil and leeking water everywhere - Now runs great, BUT --- have Check engine light - codes 1537 and 1538. IMRC stuck open.
What are my most likely causes? I Did not have this problem before the intake gaskets were done.
Thanks.
Thanks.
I had the same codes on mine back in July.I tried fixing it myself;looked for vacuum leaks,the actuator clips were not broke,even tried running SeaFoam thru the intake thinking it was carbon keeping them open! NOTHING! I finally broke down and took it to Ford;$690.00 later it was fixed! Both IMRC actuators were bad!
kbgrn150
08-29-2010 11:54 PM
