6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L tq vs 6.4L Maxforce 7 in the International trucks
Old 12-07-2006, 06:56 AM
powerdog's Avatar
powerdog
powerdog is offline
It is funny the 6.4L Maxforce in the int. trucks has a peak tq rating at 1400RPM’s vs. the 6.4l tt in the super duty at 2000RPM’s. This tells me that ford chooses to keep max tq at close to 2000rpm’s for drive train durability or for better performance.
Old 12-07-2006, 07:56 AM
origcharger's Avatar
origcharger
origcharger is offline
Yes, they did that on the 6.0/VT365 also. It leads many to falsely believe that the peak torque is at 2,000 becuase its a V8 and incapable of producing low end torque similar or better than an inline engine.
Old 12-07-2006, 08:06 PM
duramaximizer's Avatar
duramaximizer
duramaximizer is offline
I read somewhere that the 6.4 maxxforce only uses 1 turbo also. Anyone got the info on that?
Old 12-08-2006, 12:50 PM
IHbase's Avatar
IHbase
IHbase is offline
It is a trade off and for the consumer market, everone thinks they need 300+hp in a truck. But in work applications, torque seems to be a lot more important. Witness the high torque low hp formula in all heavy truck and tractor applications.
As for your drivetrain durability point- not so much an issue. Engine manufactures have been limiting torque in lower gears for just that reason for years and maping higher torque in higher gears. So, in theory, they could map around crazy high torque numbers by limiting output in certain ratios.
-Mike
Old 12-08-2006, 01:10 PM
kw5413's Avatar
kw5413
kw5413 is offline
Welcome to FTE and the 6.4 forum IHbase
Please take a few minutes to read up on our site guidelines.
https://www.ford-trucks.com/guidelines.html
</WMFILTERED>
Old 12-08-2006, 06:19 PM
jmcholden's Avatar
jmcholden
jmcholden is offline
It would be realy great if they would let the customer map thier own torque and HP curves according to each persons needs, or at least let you choose from a few?
-Mike
Old 12-08-2006, 07:10 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
Isn't that what the chips or programmers are supposed to do? I don't know as I've never had one before. If I remember right, on some systems you can choose different levels of power, shift points, etc.
houseofdiesel
1999 to 2016 Super Duty
15
07-07-2014 03:16 PM
SANDDEMON08
12-22-2013 10:44 PM
6LPSD
01-31-2008 09:21 PM
LPD111
Ford vs The Competition
40
12-08-2003 11:46 AM
Quick Reply: 6.4L tq vs 6.4L Maxforce 7 in the International trucks
