im tryin to save my trans from blowin, it works fine most of the time, it just tends to over heat a little and starts having trouble shifting, i therw in a shift kit and a trans cooler and a temp gauge, which helped it dramaticly! but it still does it from time to time, is there a high performance trans fluid out there that i can use to help my trans? i know bully dog has same special fluid it it any good? im pretty much tryin to eliminate as much clutch slippage as possible, thanks! and its a e40D in a 1997,
