General Automotive Discussion
99 Mercury Mystique Rear Brakes
Old 11-28-2006, 07:00 PM
51dueller's Avatar
51dueller
51dueller is offline
I just put new rear calipers on my 1999 Mercury Mystique. The calipers do not seem to be adjusting up to the rotors. I have long pedal travel before the rear brakes engage and if I give it a little pump, I get a hard pedal. The integrated park brake mechanism works fine but when released the pads have almost 1/8" to the rotors. The brakes have been bleed twice. Would it help to bleed it while the park brake is on?
Old 11-28-2006, 07:10 PM
Krochus's Avatar
Krochus
Krochus is offline
Try setting/releasing the E-brake a couple dozen times.
Old 11-29-2006, 02:35 PM
thefarelaneman's Avatar
thefarelaneman
thefarelaneman is offline
needs more fluid in the lines
Old 11-29-2006, 03:36 PM
aerocolorado's Avatar
aerocolorado
aerocolorado is offline
I'm pretty sure your rear brake system is the same as our '95 Contour. On the rear, there is a caliper retracter that has to be released after the new pads are installed. Could be your retractors did not release. Here's a link to an online repair manual for the rear brakes:
http://www.autozone.com/servlet/UiBr...3d801bd90d.jsp
poq-ff-19
1999 to 2016 Super Duty
10-18-2013 12:28 PM
ChuckRob
07-24-2013 07:15 PM
Bruker
17
10-29-2007 01:54 PM
Msp541
05-24-2006 06:05 PM
goose213
1978 - 1996 Big Bronco
11-22-2004 03:12 AM
Quick Reply: 99 Mercury Mystique Rear Brakes
