Question for your thermodynamicists out there.
Well based on more of the information. Let's rough out what you have.
So let's say you have 1 CI of gas at 100F and it's ignited to 1000F, how much would it expand?
Again, PV=mRT Pressure*Volume=mass*(constant)*Temp
Pressue stays the same - because the volume will change and since we don't know enough about the situation
m stays the same
So basically all we can say is that delta V is proportional to delta T. It isn't EQUAL to delta T, but proportional. We just don't have sufficient information here. Mainly how much air will expand after being heated up by 900 F.
The final pressure doesn't matter, the final volume doesn't matter - they're just variable with unspecified values.
Here's a link that defines this stuff better than I can, it's just been far too long for me
http://www.heliosat3.de/e-learning/A...ection3_02.pdf
m stays the same
Originally Posted by thefarelaneman
Why in the world would anyone want to know the answer to a question like that?
With all these terrorist running around and stuff some things need to be kept a secret
.......Gezzzzzz next thing people will want to know is "how many grams of TNT does it take to blow the tires off a 727" gez
Originally Posted by PSKSAM2
I was never so great in Thermo, but I'd question the assumption being made that a fuel-air mixture is an ideal gas (applying the ideal gas law, PV=nRT).
-Jim
-Jim
-Jim
-Jim
I think, forces that are more or less negligable, can be ignored, at least until someone fugures out the explosive force of the fuel charge.
Wouldn't it be based on the calorie or joule content of the particular fuel. That would equate to the fuel's ability to do 'work' more than anything else.
Originally Posted by furball69
A stoichiometric fuel ratio means that there are 14.7 parts of air for every part of fuel. At this ratio, fuel in a perfect combustion chamber would burn off completely. The products of stoichiometric combustion are water (H<sub>2</sub>O), carbon dioxide (CO<sub>2</sub>) and oxides of nitrogen (NOx). Note that NOx is a pollutant.
In any case, I was thhinking a bit more about the original question, and as it was asked, it's exceedingly difficult, or nearly impossible to answer it precisely without actually doing an experiment and measuring the pressure and temperature.
The main problem is that gasoline is a mixture of hundreds, or maybe even more various hydrocarbons and a few other compounds, and so one would need to know the exact composition of a given gasoline sample and figure out how much heat each compound would produce, and then sum them up. It's not that difficult for mixtures that contain a few compounds (i.e. propane and butane) but with few hundred compunds, that's a bit too much. The problem is that one can't simply go on H and C content as the heat given up is different for single, double and triple bonds between C atoms.
IMHO, the simplest thing would be to rig up an engine with a pressure and temperature sensor somehow, or do a search and try to find out if a similar question had already been answered. An approximate answer can be obtained if one assumes gasoline to be a straight chained C8H18, however.
#29
