Texas Chapter Join Chapter, Leader: LibTimothy
Me & My Explorer gittin out of Calif. & Comin to San Antonio- FINALLY!
Old 11-16-2006, 05:25 PM
roborob76's Avatar
roborob76
roborob76 is offline
Had enough of Calif. & Comin to San Antonio- FINALLY!
We're finally gettin out of here and moving to SA-
Out here (calif.) we got tons of smog crap on our trucks- from what I've seen, in Bexar county you have to pass only a vehicle safety check to get registered. Does mean i can yank the smog crap off my truck and let her breathe ?
Old 11-17-2006, 04:59 AM
truckertaz's Avatar
truckertaz
truckertaz is offline
I don't know about the smog crap, but we will be moving close to there soon also Probably not as soon as you but soon
We are moving to San Marcos in 2 years... It will be the longest 2 freaking years of my life
Old 11-17-2006, 06:33 AM
jdbanks's Avatar
jdbanks
jdbanks is offline
There are different emissions standards in different areas. In Houston, you have to have an older vehicle to be exempted from the emissions test at inspection time. What year is your truck?
Old 11-17-2006, 10:19 AM
roborob76's Avatar
roborob76
'95 explorer-Bexar County/SA-outside the west side of 1604 loop
JD-
its a 95 , which aint that old I understand. . but a family member just moved down there and they didn't need to get a "smog" check. just a safety inspection ? on a 2001 honda
Old 11-18-2006, 08:23 AM
TXFX4's Avatar
TXFX4
TXFX4 is offline
it all depends on what county you are in. the closer you are to the bigger citys the more likely you will have to have an emission test. and if the vehicle was equipped from the factory with certin emission parts the are required to still be on their and working even if you are not in Cali.
