Is 5w-20 Oil OK in a 99 V-10?
Pete,
There is very little difference in the drivetrain design between the 99-04 2v v-10's. The only difference (upgrade) was mainly to the exhaust flow/intake system in early 02 to get more HP and torque out of the beast. The engine is basically the same, and 5w20 Motorcraft synthetic blend would be what I would suggest going to to make the swap. You will probably find your engine running a bit smoother with the change. You will be alright running 5w20 in your 99 2 valver....
-Casey
-Casey
