My tilt hinge is a BMW hood hinge. I believe most of the kits used the same hinge. When I received the kit from No Limit it still had the BMW part number on it. If you get the hinge then you just need to build the rollers, hood latch and supports.
a friend of mine uses Buick reverse opening hood hinges on his kits. They work better than the others as you don't need a prop rod to hold the hood open. He builds them in his spare time. Send me your email address and I will forward it to him.
Hello Truckfarmer, I was just browsing the message boards and came across your reply about reverse opening hinges made by your friend. I have a 55 F100. It sounds like these might be right for my truck. Please e-mail info to John at:
jcdawson_us(No Email Addresses In Posts!)
Truckfarmer: I have a tilt mechanism from a buick Lesabre and would like info on modifying it for my 53 f100. Any info you may have would be greatly appreciated. Thank you, tlm9999(No Email Addresses In Posts!)
