Should I inflate my tires to the recommendation inside the door or on the sidewall of the tire? I currently have the stock 275/70-18E Continental tires on my truck.
Use the recomended tire pressure on the door when you are hauling weight for tire longevity but when empty I air down to 55 - 60 front and 55 psi rear. You can tell by chalk testing tires, full air on an empty truck you will wear out the centres fast without airing down a bit.
