felt between fender and box
A couple of ideas (I've used both in different places on my truck):
1. the silicone is good as a "seam-sealer" and of course is good to prevent water from getting in between and creating rust. How effective it will be as a "buffer" between the rear fender and the bed (box) of the truck is questionable, I'd think;
2. as a "buffer" between my fuel cell and the bracket that holds it in place behind the rear end melon, I used solid rubber cut into strips (sized) along the rails between the fuel cell and the bracket that holds it in place. The rubber can be 1/8" thick; 1/4" thick; 3/16" thick; or whatever thickness is: (1) afforded by the gap between the fender and the box; and (2) sufficient to serve the purpose it is intended for.
I got the solid rubber from a local textile manufacturer where they sell everything from rubber like I got to rubber and plastic tubing, rubber hosing for industrial equipment, etc. I don't know where you're located, but it's called "Delta Rubber". They're in Visalia, California. Their E-mail is: www.deltarubber.com. Their phone # is: (559) 651-0311 or (800) 607-0311. If they can't help you or it isn't feasibile to do business with them because of proximity; shipping; etc... maybe they know someone in your area or can recommend someone to you?
Anyway, good luck... hope this helps!
Daryl
Daryl
