Transmission swap?
Old 10-15-2006, 10:30 PM
norwestie's Avatar
norwestie
norwestie is offline
Transmission swap?
I have a '66 Ranchero with a factory 289. The tranny is a floor-mounted 3 speed. I have an opportunity to get a '68 Ford 1/2 ton pickup cheap. It has a 300ci 6 banger with a 4 speed. Would this tranny work in my Ranchero?
Old 10-16-2006, 12:11 PM
cobraguy's Avatar
cobraguy
cobraguy is offline
If it is a granny low 4spd no.
Old 10-18-2006, 06:16 PM
norwestie's Avatar
norwestie
re: swap
Apparently the shifter is much further forward on the truck transmissions. Okay if I had no dashboard ; {
Any one know what other model 4 speeds would swap out in my Ranchero?
Old 10-18-2006, 07:28 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
A Ford Top loader 4 speed is probably a direct bolt in. It was in my '65 Mustang.
Info on these boxes:
http://www.4speedtoploaders.com/
this guy does 'em right, not cheap, but lots of info regarding models etc.
Another site with lots of info:
http://www.5speeds.com/toploader.html
Did someone say 5 speeds? If you are going to the trouble to swap out, a T5 will bolt in also, giving you OD for low rev hiway running. Some sites with info.
http://www.moderndriveline.com/
These fellers got right back to me when I emailed them. The sell packages including cross members.
http://www.ttcautomotive.com/English/products/T-5.asp
info galore.... including other models with movable shifters.
http://www.allfordmustangs.com/Detailed/631.shtml
how to ID the T5 if you visit your local scrappy in search of same.
Good luck.
Ranchero_Boy
02-02-2014 08:03 PM
50J03
03-25-2005 11:41 PM
oregon ranchero guy
12-12-2003 06:51 PM
Quick Reply: Transmission swap?
