Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #76 (permalink)
Old 04-02-2007, 07:59 AM
frederic's Avatar
frederic frederic is offline
frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE.
Yep, easily built, but I'd need thick wall square tubing which I don't have enough of. Also if one makes the head interchangable (with bolts), one can remove the 8" wheel and mount and replace it with a pneumatic impact chisel gun thing with a homemade foot for a planishing hammer. Been looking at those DIY designs too.
I get injured from staring at machinery so not worried about a few blood blisters my friend
  #77 (permalink)
Old 04-02-2007, 12:51 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
You can pick up LED lights for that module I mentioned on Ebay.
Item number: 190098818188 is for a blue one but you can get white and other colors also. The little 194 bulbs that some clearance lights use are also available at the parts store or ebay.
My application for that part is emergency lights for the basement and shop. I have a commercial 12V E-light unit that I can just run some 18AWG bell wire from (fused) to power a bunch of those fixtures with LEDs in them at strategic locations. I hate it when the lights go out and that power tool is still spinning...
Remember electronic voltage regulators have to be derated by a factor of a 3 to 10 depending on how good your heatsink is if you do not have an "infinite heatsink" for them. Otherwise called a circulating oil bath....
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #78 (permalink)
Old 04-10-2007, 10:29 PM
frederic's Avatar
Made the hinged bed floor. With the lock installed (not show in the picture) I can keep my son's fingers away from the hot motor, the chain and the batteries, and still have access without having to remove the body.
http://frederic.midimonkey.com/booto...r/IM002328.JPG
Three coats of grey rustoleum primer out of opened quarts lying around. MDF absorbs so much paint I decided to waste primer lying around rather than have it absorb the new can of hammerfinish paint I just bought. In this picture you can see the grey hammer finish paint drying in the sun, hence the brush strokes. They go away once it's dry which is about 30-40 minutes tops.
http://frederic.midimonkey.com/booto...r/IM002332.JPG
And this is after two top coats of "Safety blue", the color my son picked out while we were at ace hardware.
http://frederic.midimonkey.com/booto...r/IM002333.JPG
Now, you're probably wondering why I put a top coat on top of the hammer-finish coat. The answer is simple... the hammer coat is incredibly tough to damage, and if the top coat is sprayed on top of the hammer coat while it's almost dry, but just wet enough that you can scratch it with your fingernail but not leave a fingerprint, the topcoat will also be fairly indestructable. I discovered this on another project and decided to apply the concept here. This blue wasn't my first choice but my son wouldn't let go of the two spray cans so it is what it is.
After I sprayed the two coats and they dried, and my son came back outside he was jumping in a circle chanting "Blue baby truck" repeatedly for about 5-6 minutes. He seems pleased.
Next is the lighting, installation of the new wiring harness, and installation of the bed floor, seat, and various other things. Getting there slowly.
  #79 (permalink)
Old 04-11-2007, 02:37 AM
Torque1st's Avatar
Posting Legend
Looks good! Much nicer than anything I make. It is hard to get those nice corners on 1/4" plate.
__________________
  #80 (permalink)
Old 04-11-2007, 12:22 PM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE. "Beemer Nut" has a good reputation on FTE. "Beemer Nut" has a good reputation on FTE.
Before you clearcoat you must add the blue oval to the tailgate and grill.
__________________
.....=o&o>.....
  #81 (permalink)
Old 04-11-2007, 12:59 PM
frederic's Avatar
I have the ford insignias, just haven't glued them on yet. ALso haven't figured out what I'm doing for a grille. Probably painted on.
I'm open to ideas if you guys have any... though I'm trying to get this on the road very soon since it's spring already...
  #82 (permalink)
Old 04-11-2007, 01:10 PM
A scrap sheet of aluminum, cut out for grill (give it a 68 look) plus doors for the headlights. Hit it with a palm sander for a custom finish look, mount with countersink screws. This way you have a 3-D look vs just painted on, hell your this far don't cut corners.
__________________
.....=o&o>.....
  #83 (permalink)
Old 04-11-2007, 08:39 PM
Torque1st's Avatar
Posting Legend
A section cut from an old shopping cart might look OK. Maybe the section for the baby seat. Two spots for lights where the leg holes would be.
__________________
  #84 (permalink)
Old 04-17-2007, 08:27 PM
Bdox's Avatar
Bdox Bdox is online now
Iconoclast
Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation.
Quote:
Isn't that what GM uses for Cadillacs?
__________________
Bruce, Nevada Chapter (gone power mad!)
A worthy goal is to try to be counted among the ethically and intellectually valuable people.
Did you get that air guitar that I sent you?
  #85 (permalink)
Old 04-17-2007, 08:49 PM
That would be a plastic K-Mart cart stuck in the grill after cutting thru a parking lot at speed.
Hey any snow falling in Tahoe?
__________________
.....=o&o>.....
  #86 (permalink)
Old 04-29-2007, 10:17 AM
frederic's Avatar
Some more prgress was made yesterday. I disassembled the entire car, and painted the chassis with rustoleum's hammer finish paint, grey, just because I had more than enough lying around. The paint is excellent for surfaces (particularly metal) where there are surface imperfections - welding beads that aren't ground too much, minor seams and stuff, a couple of mig balls stuck... etc.
http://frederic.midimonkey.com/booto...r/IM002364.JPG
Before I can make a grill, I had to decide what lights to use. We had discussions on this thread for several different choices, but I never got around to ordering anything for no reason other than I didn't get to it. Last week the "emergency light" I had installed in the basement finally died - circuit board failure - which is not suprising considering I plucked it off the curb many years ago - so I scavanged the light housings and chucked the rest. I made a simple metal support for the lights, like so:
http://frederic.midimonkey.com/booto...r/IM002363.JPG
And viola, instant headlights. I'm going to pick up 12V bulbs today to replace the 6V bulbs that are in there now and wire them in series, attaching them to the body harness connector with the throttle. Then all I need to buy are batteries.
http://frederic.midimonkey.com/booto...r/IM002362.JPG
Oh, and I had forgotten to paint the bottom of the MDF body so I did that last night as well, using the same grey hammer finish paint since I had the brush in my hand and the can open.
http://frederic.midimonkey.com/booto...r/IM002365.JPG
So today I will reassemble the car and order the batteries if I can get to it. Going to use sealed lead acid batteries designed for wheelchairs, since the ones I picked out fit into the allotted space and also they are deep discharge, so they won't permanently die by being run down to near zero.
  #87 (permalink)
Old 04-29-2007, 11:29 AM
CheapRanger CheapRanger is offline
CheapRanger is starting off with a positive reputation.
Once your done with this, you gonna start building his next car?
Time goes by fast...
  #88 (permalink)
Old 04-29-2007, 03:17 PM
A Junior dragster?
NHRA legal Briggs & Stratton powered.
__________________
.....=o&o>.....
  #89 (permalink)
Old 04-29-2007, 07:12 PM
tjc transport's Avatar
tjc transport tjc transport is offline
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
here is a pic of the grill emblem for johns truck Fred.
it is 7 inches long and 2 3/4 inches high, with 3 mounting studs on the back.
i think it is a pickup grill emblem, cause it is about 1/2 the size of the heavy duty truck grill emblem i have on my truck.
http://i41.photobucket.com/albums/e261/tjctransport/emblem.jpg
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #90 (permalink)
Old 04-29-2007, 07:51 PM
frederic's Avatar
Very cool, thank you! If it's overwhelming on the front of the truck because of the size of the headlights, I'll put it on the tailgate since there aren't any lights there yet, and I'll probably be doing something smaller back there eventually.
BTW, if those are the measurements, it's off a van grill which are larger than the pickup grill emblems. Not that it matters
Tags
il11cs , optronics
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
