Legalaties of purchasing another trucks Vin plate
Guys whats the legalaties of purchasing another Vin Plate from the same model truck and adding it to my truck which has no Vin# or plate , (the dash has been removed completely )
The truck has Arkansas plate SSE-499 but the plate is not current within the last 5 years so i havent been able to track the original Vin # down.
Also the Truck will be exported so it will not show on your systems there as far as DMV etc, but id like to at least have a Vin # for it on a title.
Received 1,353 Likes
on
Originally Posted by alchymist
Have you checked the frame rails for the original VIN number?
The VIN should be near the front on top of the frame rails. Mine (56 M100) was on the driver`s side just behind the wheel but it can vary as it might be on the pass side as well from what I have read. It maybe hard to find with dirt and rust build up but if it`s cleaned up well it can be found unless some frame repair work was done.
When I bought my 1956 F100, there was no VIN plate on it. I was able to find the VIN stamped into the top of the frame rail on the passenger side, just rearward of the firewall. The DMV will use the frame-stamped VIN for dentification and titling purposes. Replica VIN plates are also available.
Originally Posted by Fomoko1
That maybe the best as it might found later causing alot of problems depending on how much it`s checked over during export.
Me too!
When your new truck comes look in the glove box (or whatever you folks in the land of the 'roos call it that compartment in the dash). 53-55 had the vin # plate attached to the inside of the box door. Unless the inspector knows to match it with the one stamped on the frame (or someone has already removed the one inside the cab) you should be good to go.
on
If you're missing the data tag, and have the title and a stamped vin in the frame, just have a new data tag made. I had a new one made this past summer as mine was missing. I got mine from datatags.com.
http://www.datatags.com/
Bike
