Please help ID my rear axle
Up-front I would like to apologize for my English; it is not my first language.
Vehicle: 2003 F350 V10 6.8L
I am trying to ID the rear axle so I can order a rebuild kit to set in new bearings ex. in the diff-case
<o> </o>
All the info I took of the truck is listed below
<o> </o>
12 Bolt
Labels = 3V423F
731052L27
Only Use 80W-140 Synthetic
Back center case stamped = A GSC 1
Front center case stamped = F81-AA
<o> </o>
Driveshaft = 2c34-4k145-FFA
Dana = 923377-2
K0217-101DL
Date: 11-07-02
(H2239)
Thank you in advance for your time and comments,
Tristan Burm
<o> </o>
<o> </o>
12 Bolt
Labels = 3V423F
731052L27
<o> </o>
Dana = 923377-2
K0217-101DL
Date: 11-07-02
(H2239)
Tristan Burm
Look at your label . . .
Look on your drivers post for the Viehicle cert label. It will give you a code there as to what you have. This is from the tech folder in Super Duty section
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
First, WELCOME TO FTE!
Second, it looks like you have 3.73 gears, because the tag usually has the first number under the bolt head, so the tag saying "73..." really says "3 73...". And it's not a limited-slip Traction-Lok.
If it's a 2003 3.73 V10 with single-rear-wheels (not DRW) it's a Sterling 10.5"
Flintknapper
17
02-18-2015 08:00 PM
bkuuz1
05-02-2014 09:47 AM
Perls
23
10-27-2012 12:38 AM
