Help with heated seats
#77
Well I did it. I took the seats out, it makes life a lot easier, and sure enough there was a burned wire. In each seat. I soldered replacement wires in. Put some electical tape over the joints. It is too late now to go for a ride. I will be checking it out soon, though. I am going to Montana next week. That ought to test them out.
#78
#79
#83
#87
#88
https://www.ford-trucks.com/forums/5...ted-seats.html
#90
I purchased my 01 Excursion 7.3 about a month ago. This is my first Ford and my first diesel and it's been a joy so far (for the most part). We bought it mainly for towing our travel trailer but my wife wanted it to have heated seats. We searched near and far for the one we found and eventually found it in OK, about 1200 miles away from CA. Anyways, long story short-the heated seats didn't work. I found this thread and went to work on the seats. The lights on the switches would come on and the fuses were fine, but there was no heat. I started with the passenger seat and checked the continuity and there seemed to be resistance (I am no electrician, but I checked the 3 and 5 wires and my multimeter moved to a different number besides the number one on the ohms setting). I pulled the seat cover up and checked the heater area on the cushion actually hoping to see a burnt area but there was none, so I put everything back together. I tested it again and there was actually some heat. I don't know, however, if it is as hot as what others are talking about. Am I just expecting too much or could this mean the heating element under the seat is slowly going bad?
I started working on the driver's seat and there is power going to the switch on the seat trim but there is no resistance between the 3 and 5 wires. Would this be a symptom of the wires being burnt under the leather, a bad Bosch heating element or something else? I haven't gotten around to removing the whole driver seat yet. Any help would be greatly appreciated.
