2004 F150 Rear Door Panel Removal
You need to remove the plate behind the door handle, take that screw out. Pop off the two pieces on the top of the door take out those screws. Remove the screw at the bottom also the power window panal has a screw behind it. After all is removed the door panal will just lift off, don't pull it will break the tabs just pull up.
watercamper
29
10-23-2018 09:46 AM
Supercab
09-15-2002 07:24 AM
