84 f150 wiring diagram
Old 09-16-2006, 06:05 PM
jano's Avatar
jano
jano is offline
I bought this very used 1984 f150 about 5 years ago. Someone had put it a 350 in it and rewired it. Lots of wires that don't go anywhere, just taped off. Last week I drove it home, next day it wouldn't start, no lights, nothing. Battery and cables are good. Appears a wire from the harness to the solinoid was fried. In the process of trying to track down a possible open wire/short the entire harness started to disintegrate on me. I probably need to get another one, but need a diagram to know what wires go where. Any ideas on what wire this was and/or where I could get a diagram and a different harness?
Old 09-16-2006, 06:18 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
A smaller wire hooked to the solenoid underneath the large wire going to the battery +? If so, this is the main electrical feed for the whole truck.
The factory wiring diagrams are made by www.helminc.com. See if they have any in stock. The cheapo haynes manual has a pretty good set in it for 84-86 trucks.
If you want to start experimenting and troubleshooting the wiring, hook a small battery charger up to the battery cables and disconnect the battery. The battery charger has a circuit breaker in it, so if there is a problem, the wiring will not melt till you get it sorted out.
zekelander
1997 - 2003 F150
01-07-2021 12:28 PM
marky55
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
04-07-2009 02:21 PM
thepitshop
11-15-2008 05:57 AM
noahr
2004 - 2008 F150
01-11-2005 10:11 PM
Quick Reply: 84 f150 wiring diagram
