Just wondered this, say you're happily driving along (ok ok under hard acceleration) with nitrous on and you shift...what happens with the nitrous still flowing? Is there a valve that cuts it off, or does it just spray into the engine and combust with no problems until you get on the gas again?
There is a WOT switch on nitrous kits that only allows it to spray when you are at full throttle. When you let off the gas to shift the nitrous quits spraying.
I think there's a throttle cut-off switch, such that when you release the gas pedal to shift (you do that, right?) the nitrous is cut off until you hit the gas again.
