'07's OK to ship
This may be whats holding the Expeditions up:
2007 FORD EXPEDITION TIRES:TREAD/BELT
Recall Date: 07/06/2005
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE FRONT AND REAR TIRES ON THE DRIVER??S SIDE OF AFFECTED VEHICLES MAY HAVE BEEN DAMAGED AT THE CENTER TREAD DURING PRODUCTION.
Consequence:
OVER TIME, THE DAMAGE MAY BE SUFFICIENT TO ALLOW BELT CORROSION ULTIMATELY LEADING TO A TREAD SEPARATION, WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT ALL FOUR TIRES (TO ENSURE INSPECTION OF THE LEFT HAND SIDE TIRES THAT MAY HAVE BEEN ROTATED TO THE OTHER SIDE OF THE VEHICLE) FOR TIRE TREAD DAMAGE AND, IF NECESSARY, REPLACE THE DAMAGED TIRE. THE RECALL BEGAN ON JULY 13, 2005. OWNERS MAY CONTACT FORD AT 1-800-392-3673.
Potential Units Affected: 10061
Notes: FORD EXPEDITION 05S35
Summary:
Consequence:
Remedy:
Usually not a good sign when they issue a recall before the vehicles have even hit the dealerships. But I think the most disturbing part of this recall is that they are asking dealers to inspect the tires for damage. Since "corrosion" is a concern, one can only assume the potential damage is internal to the tire. I've never seen a dealer (car, tire, or otherwise) who can inspect the internals of a tire.
Originally Posted by landstroker51
This is all a hoax. There are no 2007s. When I see one in person I will believe. This is getting good...
Originally Posted by maryfshort
NCKRACER...Why is this recall date 2005...when production hadn't begun until 2006? I am very confused...
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
http://www.internetautoguide.com/aut...ion/index.html
http://www.carseverything.com/256/20...n-recalls.html
http://www.motortrend.com/cars/2007/...lls/index.html
Don't shoot the messinger!!
I actualy work at the plant that makes these trucks and, what happened is that on of the guides in the floor came loose and ,were sticking up. It tore up some tires but, The problem was taken care of pretty quickly. You need to give us a little room to make the best product that we can...our asses are on the line!
Blue Oval News Forums
hadman50
12-10-2006 01:57 PM
