Idle jumping aroung when A/C is on
Hello everyone,
I have an 2001 F150 supercrew with the 4.6L. It runs and drive's fine but when I turn the A/C on and just parked or at a stop light the idle just up and down. It just started the other day. Its fine whem i'm driving but as soon as i stop it goes from 800 RPM's to about 1500 RPM's. IF anyone can help i'll try anything. Thanks
When I had the same problem, I checked for vacuum leaks first. I ended up changing my IAC valve which helped (You can also clean these but results vary greatly). The last step was cleaning my MAF sensor - and voila! Problem solved and (bonus) I actually increased my gas mileage when I cleaned the MAF. I would clean your MAF and IAC, as well as check for vacuum leaks first before spending $70 on a new IAC valve.
