Fuel Injectors on a 93 4.9 I6
My truck has been running really rough. It idles rough and when you go to take off from a stop it sputters in first through 3rd gear during excelleration.
Seems to run fine at speeds above 40mph.
I changed the spark plugs, wires and distributor cap. Still having the same problem...
Ran fuel injector cleaner through it, no change.
Checked for intake leaks, there are none. I do have a small exhaust leak on the exhaust manifold.
What do you guys think?? Should I have the fuel injectors checked out?? Something else I should be looking for??
johnvirgil
30
12-07-2015 04:52 PM
