Need cable - accelerator to transmission
I need to replace the cable that goes from the accelerator pedal to the automatic transmission on a 88 Bronco II. I have been told that it is either a kick down cable (TV) or a overdrive cable. The casing on the cable is broken with casing wires explosed and nicks in inner cable. I have had no luck on typical sources for replacement. Any ideas?
E8TZ7A187A .. Kickdown Cable / Obsolete / Fits: 1988 Bronco II & Ranger with A4LD.
No Ford Dealer or obsolete parts vendor has any.
It isn't the cable ends that are the problem. It looks as if the previous owner let it get to close to the headers and the casing is melted away, leaving only the wire strands of the casing and the cable. The missing casing area is large and there are nicks in the cable, which looks to be plastic and it has a few cuts in it also. If you or someone else doesn't have a spare cable that I can get, I will have to search junk yards as no one appears to have a new one. I don't know what years/models will work, so I will have to take it along with me. Thanks.
D8TZ7A187A .. Kickdown Cable / Obsolete / Fits: 1988 Bronco II & Ranger with A4LD.
schoo
05-31-2016 09:10 AM
bigcrunch
01-04-2016 12:24 PM
timber_cruiser
09-26-2011 10:42 AM
88, a4ld, accelerator, adjustment, aod, broken, bronco, cable, f150, ford, ii, kickdown, linkage, transmission, tv
