2001 power window
Hi and welcome to FTE
It's not all that common but I've seen it a few times. Usually the problem is the power window motor. You can remove the door trim panel (instructions in the Frequently Asked Questions at the top of the forum) and check for power at the motor when you press the switch. If there's power there then the motor is bad. You can try tapping the motor gently with a small hammer or wrench and see if that "unsticks" it.
