They very well may be pressed on. The windsor motors had pressed on cam gears where as the Romeo motors have bolt on cam gears. You would have to buy a set of bolt on cam gears to swap cams.
Thanks for the help guys. im gonna be porting the heads soon, and port matching the intake, putting on headers and full exaust, machining a bigger throttle body and machining the intake to match, throwing an ac bypass pulley on and getting rid of the clutch fan real soon, would love go top it all off with a set of cams. i was just wondering about the cam gears because i want to make sure i have everything ready to go when i start. thanks again.
