'04 2WD Expedition Lift Kit ideas?
I've been thinking about geting a 4" Rancho truck lift for the front and a 2.5" Daysar for the rear for my 03. I think it would sit level because of the rear being high to begin with.
Right now I have a 2.5" spacer in the front that I bought on eBay and I am only using the strut spacer of a daystar lift in the rear for about 1.25" of lift (not using the coil spacer). It's still seems a little high in the rear. But it does look better then 2.5" in the rear.
-Wayne
-Wayne
I did the daystar front and rear plus went to 33" tires. I picked up a total of 3.5" (measured at the wheel well lip). Looks a lot better, but no quite enough.
I'm thinking of adding another strut spacer on each corner for a little bit of help.
The '04 has the IRS so I can't use any kind of off the shelf lift kit.
My 03 is also IRS. The only off the shelf lift I have found is at http://rizeind.com/ I've heard that Full throttle suspension also has one but it's not listed on there website.
In the front I think if you stack the spacers you may have problems with the spindle contacting the spring. The rear may bind the cv joints up.
With your Daystar lift does it sit level?
glockholiday
03-09-2017 03:39 PM
davesexpedition
1997-2006 Expedition & Navigator
13
01-13-2017 09:44 PM
EPI-911
10-03-2015 07:46 PM
