alternator fuse
Old 08-05-2006, 02:17 PM
exploranger's Avatar
exploranger
exploranger is offline
alternator fuse
Hi guys. Got a new opportunityfor learning. Had a problem with the alternator not charging on a 99 F150 on Thurs. after much testing and brain scratching, I found a blown alternator fuse (20 amp mini fuse in slot 11 of the fuse panel ) under the hood.Replaced that and everything worked just fine till Fri night when it blew again. Checked as many connections as I can find, but haven't found anything that Ican say was a problem. Any ideas where I might narrow my search?
Old 08-05-2006, 06:32 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The voltage regulator portion of the alternator is going, going, go.....
Steve
Old 08-15-2006, 08:52 PM
exploranger
For anyone that might be interested, it turns out that the regulator kept testing that it was good, but so did the alternator, and continually blowing the ALT FIELD fuse. Finally, on the third time it was hooked up to the test bench, the output wires were attached, and when the case ground was put on, it arced. So the rebuild shop went through it again, changing out all of the electrics. has worked for a week now and not blown another fuse.
Old 08-15-2006, 11:57 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Thanks for letting us know what fixed it
bluzzer
1999 to 2016 Super Duty
58
11-01-2016 11:43 AM
WWR
1997 - 2003 F150
07-13-2016 11:31 AM
Beast12
Electrical Systems/Wiring
23
01-02-2012 09:29 PM
THUNDERBOLT5150
1997-2006 Expedition & Navigator
04-28-2009 10:34 AM
blaster452
1983 - 2012 Ranger & B-Series
08-11-2006 03:07 PM
Quick Reply: alternator fuse
