Is any one aware of an oversized oil filter that works well with the 97' F250 5.8L engine block? I seem to remember that my (former) 93' used a Motorcraft FL1A, but my 97' uses some dinky little thing. Or am I chasing a ghost?
that "dinky little thing" is the same filter as the 4.0, 4.6, 5.4, and 6.8 use. and if you use a bigger (read: longer) filter, you risk catching it on suspension and frame when the engine twists. change your oil at 5K KM (3K mi) and there won't be a problem
I've got the same truck. The short,820something,is used because of the factory oil-cooler adaptor. I installed a relocator kit and now I can run the FL1A. It also emiminated the oil mess when removing the filter. Good luck.
