89 E-150 Driveshaft and Trans leak
Old 07-30-2006, 12:22 PM
Mustang 5.0's Avatar
Mustang 5.0
Mustang 5.0 is offline
two items.
1--I have a leak out the tailshaft seal of the AOD. I assume it is as easy as getting a new seal and installing.
2--Looking at the front yoke of the driveshaft, there is a large round metal piece, that appears to have a rubber spacer installed, and a second piece around that. Kind of like a harmonic balancer with the two pieces of metal bonded together with a rubber ring. It's part of the front u-joint yoke.
What is that thing for? Just NVH?
Old 08-03-2006, 08:36 AM
g0ldrush's Avatar
g0ldrush
g0ldrush is offline
I think it's a warning parts, ex: if you're universal joint become noisy it will trandfert the sound to that part so you can easely hear it before it break in parts and be dangerous
Old 08-03-2006, 09:23 AM
Casey's Avatar
Casey
Casey is offline
That part is a harmonic balancer. It is not a warning part.
The leak may not be just as easy as replacing the seal. It could be the seal, but the seal may have failed due to a worn bushing in the extension housing. You need to remove the driveshaft, then the housing, and inspect the bushing and seal. Replace what's worn.
Old 08-03-2006, 05:19 PM
rclarke's Avatar
rclarke
rclarke is offline
When you remove the driveshaft examine the slip yoke surface that rides in the seal/bushing area. Any roughness on the yoke will give you a clue as to the condition of the bushing. As Casey said above the seal doesn't usually fail unless there is a problem with the yoke/bushing. If you need to replace the bushing don't be supprised if you also need to replace the yoke.
Old 08-03-2006, 06:33 PM
Mustang 5.0
Thanks all.
riverguideguy
06-30-2013 06:45 PM
WhoIsJohnDoe
08-18-2012 07:46 PM
77F-150
07-16-2005 09:21 PM
gadams
02-04-2001 10:59 PM
Quick Reply: 89 E-150 Driveshaft and Trans leak
