5.4 sounds like a diesel????
Originally Posted by Wedgewood Lariat
How loud of a ticking and/or knocking are you hearing? I have a brand new '06 and when I open the hood i can hear the injectors and a slight tick on the top part of the engine. Sounds totally normal to me. However, it doesn't relly sound like a diesel.
Most of the time the ticking noise is the Cam Phaser. I have a good friend who is a service manager at a dealer and he told me that they were swamped last year with people complaining about the problem. My 2005 had the problem at 800-1000 miles on the passenger side. The dealer fixed the problem with a new phaser. Service time was about 3 days though. I agree the sound is bad and gets worse in my experience.
Originally Posted by Loudpedal
Just bought a 04 F150 FX4, with the 5.4 and it has a audible tick or knock to it. Seems to be worse on drivers side, but I can't hear it in the cab or during driving. Got under it this weekend and checked all the exhaust connections and looked for carbon streaks and found none, everything was tight. Sometimes it stops or lessens when you turn the A/C off, but starts back up quickly. Of course the dealer said it was nothing to worry about, never is to them, and I don't really know if I need to be worried or not, runs fine, no other problems, and has great power. Any input would be greatly appreciated.
I too have a 2004 F150 FX4 5.4 Triton that sound like a diesel, which is very annoying. I have had numerous problems with my truck since I puchased it NEW in 2004. After suing Ford and the Dealer, they decided to settle instead of going to court and one of the agreements of the settlement was they have to fix the engine noise. I can tell you first hand that replacing the cam phaser and cam tensioners did NOT resolve the diesel engine noise on my truck. They are now going to replace the cam lifters, which, I didn't realize overhead cam motors have, however, I’m not a mechanic. I just know that my gasoline powered engine shouldn’t sound like a diesel. Should they be able to fix the noise, I will let you know what the fix was.
Not a cam phaser issue on some
I have an'05 Lariat SCrew with the 5.4 with 40,000 miles and have had the noise almost since new. First, I need to let you know that my 'diesel noise' problem occurs at cold startup and continues until the engine reaches temperature. My visits to the dealer have gone as follows:
1. Cannot find an issue.
2. Replace Left cam phaser.
3. Cannot find an issue.
4. Replace Left AND Right cam phasers.
5. Dealer says that I have wrong oil and replaced my new Mobile 1 with stock.
Yep! You guessed it. The noise is still there. The dealer is being very nice about the whole thing but the problem still exists. My first car was a 1967 Ford ranchero with the straight 6 and that thing never missed a beat; even in below zero weather (BTW, I now live in Florida). I was hoping that, somewhere in the subsequent 3 decades, they would have gotten better. The only comfort I have is that all of the "domestics" have multiple issues of one sort or another.
I just had my cam phaser replaced and it made all the difference in the world. My truck sounded like a diesel when i was in a drive thru or when i was driving next to parked cars with the window down. I just picked it up yesterday and it sounds great. At first they said it was characteristic of the motor but they finally gave in and replaced them after i complained enough. I guess it takes a long time because ford doesn't even have a time estimate for replacing them, They had my truck for a few days.
My 2006 has made this noise from the start. I have 22k on it since June and haven't taken it in yet. Is the cam phaser problem on the 06's too? Man with the window down sitting at a drive thru it rattles like a diesel bigtime. I also have a slight ping at take off or if I get off the gas and right back on it.
#28
#29
My truck was having the same characteristics that you have described. My truck also had a rough idle from time to time almost like a miss. They replaced my cam phasers, tensioners, lifters, and the driver’s side cylinder head. None of which fixed the problem. After going around and around with them (see previous post) they ended up replacing the engine and this resolved the problem. The difference between the two engines was like night and day not only in sound, but power. I recommend that you stay unrelenting in making them fix it.
