Fuel Pump Pooched?
Fuel Pump Pooched?
Hi guys, I think I may need a new lift pump, but not too sure.
When I got the truck the fuel pressure was sitting at a vey low 27 lbs. I shimmed it up to 65 and it is still there, but now I can only drive a mile or so before she starts to chug and lose power. Even the idle is rough after that. It will come back after sitting and idling for a while, but then I only get another mile or 2.
At first I though plugged filter. Nope, It's good. Plugged screen between the filter bowl and FPR? Nope. Clean as a whistle. I went back through the system and even went so far as to check the screens in the fuel tanks. Both good. I checked the fuses and they're all good. Checked the oil level just in case. It's good too.
I read vwman80's post about his fuel pressure and thought maybe that's it. What do you guys think?
Sorry about the long post, just wanted to get everything out there. Thanks
el chingadero
10-26-2015 02:24 PM
fivo2fst4u
07-11-2015 06:13 PM
2ndmouse
26
05-28-2004 08:21 AM
