2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Rear end ratio on 2007 Expedition
Old 06-23-2006, 09:17 AM
tguil's Avatar
tguil
tguil is offline
Question Rear end ratio on 2007 Expedition
Guys,
New the forum. Have had Fords in the past. My first was a 1956 Fairlane club coup with a 1957 312 engine and two four barrels. Wish I still had it. Most recently I had a 1990 Bronco and 1998 Expedition. Loved them both. Right now I'm driving a Dodge Quad Cab Hemi. It's almost as much fun as the 56 Fairlane. Bought the Hemi cause it really hauls.
It's time to trade and I know that no way will an Expedition match the Hemi's performance, but I think that I would be better off with a SUV than a pickup right. The new Expedition appears to "fit" me better than the other SUV's on the market.
To get half-way decent performance, I think that I need at least a 3:55 or 3:73 rear end. What's available on the new Expedition? I plan on buying the base XLT and about the only option I will add is the trailer tow package.
Two more questions: 1) Why no locking rear differentlal as an option? 2) Where can I find information on the new six speed transmission? (I had my 1990 Bronco in the shop three times for a transmission rebuild all under warranty. Yep, I'm pretty patient.)
Thanks.
Tom
Old 06-24-2006, 02:35 PM
polarbear's Avatar
polarbear
polarbear is offline
You didn't mention 2 or 4WD. A 3.31 axle ratio is std on the 2WD, a 3.73 on the 4WD- there are no options for either. The new six-speed has a deeper low than the previous Automatic, so axle ratio is only one factor in determining the performance of the new Expy.
The std. Advance-trac, which is essentially a 4-wheel electronic anti-skid control, is not compatable with a locking differential. It also makes the locker unnecessary- four wheel anti-skid/traction control vs. 2 wheel mechanical with the locker.
The six-speed has already been in service in the Lincoln Navigator, so the Lincoln website may give more info on this transmission.
Old 06-25-2006, 10:22 AM
edgeoffroad04's Avatar
edgeoffroad04
edgeoffroad04 is offline
I thought I had heard that the 6 speed going into the MY 07's was a different and newer design 6 speed than the current one in the navi...but I could be wrong.
Marcus
Old 06-25-2006, 12:40 PM
tguil's Avatar
tguil
tguil is offline
Polarbear,
Thanks much for the information. I'll be going with four wheel drive. I thought that Advance-trac might be taking the place of the limited slip differential.
Tom
Old 03-02-2008, 01:28 PM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
The 3.31 rear axle is STANDARD on ALL (4x2 & 4x4) Optional 3.73
The EL's come Standard with the 3.73 rear axle
Old 03-02-2008, 02:57 PM
chevy24d's Avatar
chevy24d
chevy24d is offline
I read your other post relating to this and I have to disagree, at least on the 07's. I have the actual build sheet for my vehicle (4 wd - xlt) and it clearly shows 3:73 is standard. That is also what is required to tow 9000 lbs. I did see that the 2 wd versions can go to 9200lbs.
I have not tried to tow this load yet, but this is why I bought this truck. Others here have mixed feelings about this but many seem to feel it will tow just fine.
Edited - I just noticed that most of these posts are old- I hope you have some luck Semper finding someone out there with 3:31's.
Old 03-02-2008, 03:31 PM
chuck s's Avatar
chuck s
chuck s is offline
Ya beat me to it...
-- Chuck
Old 03-02-2008, 03:35 PM
chevy24d's Avatar
chevy24d
chevy24d is offline
Originally Posted by chuck s
Ya beat me to it...
-- Chuck
Great minds....
Old 03-02-2008, 04:29 PM
Tmod700's Avatar
Tmod700
Tmod700 is offline
When we purchased our 08 XLT 4x4 the 3.73 was the option and the 3.31 was the standard.
I think Semper has the 08 so he is correct for that year. What the 07's came with I have no idea.
Tmod
Old 03-02-2008, 05:02 PM
SemperFiDevilDog
Chevy24d, Chuck S, & Tmod700,
Thank you
I failed to clarify that I was refering to the 2008 model.
2007 came standard with the 3.73, right?
Old 03-02-2008, 06:29 PM
brandon4's Avatar
brandon4
brandon4 is offline
My 08 has 3.31. Standard. $75 add for 3.73. I hope I'm happy with the performance. It was built last monday, yes gate release, no ship. Anxious to see it next week I hope.
Old 03-02-2008, 07:42 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Since SemperFiDevilDog posted the 3.31 & 3.73 question about a dozen times, I looked for a 2008 build sheet. I had to register at blue oval forms to down load one. Here's the statement for the 2008's, and yes its different from 2007.
3.31 axle was made standard on 4x4 Expedition (non-EL), similar to 4x2. 3.73 axle is available as an option (X16)
Basically, per the order guide 3.31 (X15) is standard for non-el 4x2 or 4x4. The 3.73 (X16) is standard on EL's and SSV (Special Service Vehicles - Police etc). The 3.73 (XH6) LIMITED SLIP, is only available on the (17L) EL Limo Prep package.
Old 03-02-2008, 08:47 PM
SemperFiDevilDog
Ford sells the 3.31 rear as Standard equipment on ALL 2008 Non-EL models. For an added $75 you can get the 3.73 rear (option only).
The 3.73 is standard on ALL EL models.
Only the 3.31 rear (with HD Tow package) will give you 9,200 max towing (4x2 or 4x4).
The 3.73 (with HD Tow package) only rates at 9,050 on (non-EL) models.
with Tow package 9,000 (4x2 EL)
with Tow package 8,750 (4x4 EL)
without Tow package ALL 2008 Expeditions Only have a Max Tow of 6,000
Old 03-02-2008, 08:55 PM
Tmod700's Avatar
Tmod700
Tmod700 is offline
Semper I think you got a little confused on your statement in a couple places.
From Ford's Site.
Tmod
Old 03-02-2008, 09:21 PM
chevy24d's Avatar
chevy24d
chevy24d is offline
Tmod - I see the change in 08 vs 07's. As I said in my post, the 07's were std w/3:73 and the title of this thread was 07 Expedition so that is why I commented as I did. Sorry for the confusion.
I will admit it seams strange to me that a lower gear ratio would have a better tow rating.......
Quick Reply: Rear end ratio on 2007 Expedition
